I finally finished the HVAC installation. You may remember, I replaced the VintageAir air box with a Hurricane 1100, so I could tuck it in the far forward section of the passenger footwell. In addition, I put a trunk in the front and moved the radiator and condenser behind the passenger seat. When you make fundamental changes like that, you’ve definitely gone off the reservation and on your own with all the joys of engineering and fabricating every little piece.
When I installed my fuel tank, I mounted it as far forward as possible. That left just enough room to run the heater and AC lines between the right side of the tank and the chassis. There are some sharp edges there so I rounded them off and added scuff guards. I wanted to completely hide the AC lines, so I ran them thru the passenger pod and up to the top of the footwell. There is very little room to run the lines thru the top of the footwell and then hide them on the inside, so I modeled the bulkhead couplers before drilling the holes. A minor modification to the standard SLC passenger kick panel hid the lines from sight.
The Hurricane 1100 includes the evaporator/fan and an air plenum with an electronic servo valve to direct air flow to the defroster when needed. Since the hydraulic lift pump is also mounted in the forward footwell, I needed to split the plenum from the evaporator/fan so it would fit in the remaining space. The evaporator/fan is only 8” wide so it leaves lots of legroom. Just 2 other modifications are needed to the evaporator/fan unit:
- The condensation drain was moved from the aft to the forward end of the drain pan.
- A small section of the fan exhaust was removed and a small 45 degree air duct was fabricated to direct air up thru a 3”x3” hole that was cut in the top of the footwell.
Things got more involved above the footwell,
- An 8” duct was fabricated to carry the air flow to the air plenum with the defroster servo valve.
- The air plenum with the defroster servo is too tall, so I cut it down thru several steps of cut, slash and ABS glue.
- Once I chopped the manhood out of the air plenum, there was no room left for the defroster servo valve, so it was relocated.
- I tried several ways to use the standard SLC boat anchor air duct, but I could not get it to fit with an air tight seal. So I cut off the curved end of the anchor, sealed it to the underside of the dash, and added a 3” inlet duct.
- Then I connected flexible air ducts to the defroster and the 4 dash vents (I added 2 more vents to the center dash panel).
I don’t have the AC system charged yet, but I seem to get plenty of air flow thru the vents and defroster.
