A pictoral of the other half of the bumpsteer work.
The kit:
I installed the kit and noticed that it I couldn't get the compression travel out of it that I wanted with the heim at the top of the stack. I lowered it down and got it usable, but wanted to get a little more travel out of it. I threw the smallest spacers I could manage into the lathe and tapered two pairs of the them to improve their range of motion:
In the lathe:
The finished stack:
In addition, the tie rods favored shortening to work optimally with the bumpsteer kit, but shortening them reduced available thread length. The solution? New tie rods threaded up as far as the manufacturer could manage. Then cut 2" off them...
Old vs New, the difference is clear:
Next step was to taper the steering arm to accept the bumpsteer kit tapered stud. Not knowing anyone who had already owned one of these (tapered reamer), I bit the bullet and bought one. I will happily accept donations if you're interested in borrowing it. I chose the hole closer to the spindle and am quite happy with the resulting ratio. Not too fast, not too slow- feels just about right. Steering effort is fine.
So after all that, it looks like this:
I haven't measured bumpsteer post-mod but the steering is so much crisper now. The car had always tracked straight but lacked precision in transition- once weight had been transferred from two front wheels going straight to the wheel directing the cornering, things were good, but getting there was vague. Since the mod, the car has come to life in the transition. It's been well worth the effort and time. If you're thinking about it, I'd definitely recommend it. If you're not, you should.
Chris
