Jim
Do you know if the jets etc you are using are actually the correct sizes - if they have ever been used before they may have beed drilled / reamered out and then the size stated on the jet is not correct.
It can then appear you have all the same jets in but 1 or more more may not be the correct jet size and give untold problems.
Yes they are expensive but starting with a known new set could save you hours / months of headaches
I'm also not sure how the quality control on new jets is now but I've also seen some new ones not being "as described" and needed replaced
