The main problems were:
I got a an engine check light. I had OBDII 172 & 175 codes, which indicate the the motor is running rich.epper:
Bill - IIRC you are using a salvage engine. You may want to check the MAF sensor to make sure it's clean, fuel pressure I believe and did you get the fuel injectors cleaned & tested. On my several used engine installs I will send out the injectors for testing and cleaning. I've used the "witch hunter" WitchHunter Performance - Injector Cleaning & Flow Testing Services - their turn around time was 3-4 business days - there are other services available that may be closer. I also don't like using "oiled" air filters - over oiling them by accident can have some ill effects on the MAF.
Just some thoughts...
Oh BTW -- congrats on 1st start & drive.
